Lofting issue / bug / I'm not doing this right?
I'm having issues with lofting straight line profiles along a single complex rail.
The final surface has the cross-section curved and kinked - even though the 1st and last cross section are straight lines. What am I doing wrong?
I've tried
- adding more cross-sections the surface likes to turn into complex curves on either side of the profile
- trying to do 1/4 of the rail with GO, G1 & G2 (with some horrible twisting with G2)
- tried doing 1/2 of the rail with same results.
However if I take the same surface to Rhino I'm able to generate the surface with no kinks using a 1-rail sweep command. Actually I was able to generate the 2 surfaces in one step allowing the hard edge to blend into a single edge at the tip.
Is it a limitation, me or bug?
Thanks in advance
