Loft - Self intersection or bad geometry
stefanSDBWG
stefanSDBWG
Hello Team
I am struggling to create a loft with a sketch that has a rounded corner. All lines intersect and I am using two profiles and a centreline. I have tried removing the rounded corner and placing a line across the corners but have the same issue.
The one problematic point/corner seems to fold on itself.
Please help
stefanSDBWG
I seem to be having the edge curling issue not just on the fourth mentioned corner but on multiple sketches and corners when using the loft feature.
Maybe it is a directional thing...
I am lost and need help please
davebYYPCU
Couple of ways to control that shape,
You may want to remove a few spline points.
Might help....
stefanSDBWG
Unfortunately, the suggested solution won't work here. I need to make a loft using surfaces and the rail used that is perpendicular to the flat face does not exist more am I able to break the continuous spline line.
davebYYPCU
Surface or solid - uses the same geometry.
Centreline rail is causing your distortion.
Check my second version selections.
Might help...
