Loft Problem
Loft Problem
elias_tzanos
Message 1 of 10
Loft Problem
elias_tzanos
Hello my name is Elias (Sorry i don't know the English language well)
I'm trying to make a loft in the images you see, but something is not going well.
When i don't use the guide rail it looks good. If i use it then the plan is not nice.
PLS Help
Thank you Elias
Replies (9)
Message 2 of 10
davebYYPCU
Works here.
Sketch 1, half Ellipse. 1
Sketch 2 half Slot.  2
Sketch 3 Line and tangent arc. R (rail)
Might help....
Message 3 of 10
g-andresen
please share the file
File > export > save as f3d on local drive > attach to post
günther
Message 4 of 10
elias_tzanos
Hello and thank for your replies. I am not on my pc yet. When I get home I will send the file.
Thank you
Elias
Message 5 of 10
elias_tzanos
In the files you can see the original piece from an Airfoil that I have imported into Fusion with Airfoil Dat to Spline. I prefer not to use the sketch but to keep the Shape from the Airfoil so I don't make any mistake. But I'll do a test and let you know if it's OK. Thanks for the help
Elias
Message 6 of 10
jhackney1972
If you attached some files, they did not make it.  You can only attach files on the Forum, email reply will not work.
John Hackney, Retired
Message 7 of 10
elias_tzanos
Hello and thank you
 I am new in the forum and i don't know how it works. Where do i have to attaché the files (isn't here the right place)
Message 8 of 10
jhackney1972
 Edit: I see the file now, you added it to an older message instead of a new one, sorry, that is a bit unusual.
Message 9 of 10
davebYYPCU
Thats weird.
You may do better with tangent condition by using the wing end, but your profile there is oversize.
Back Later....
Message 10 of 10
davebYYPCU
Sorry I can't do any better than you have got, (with all my tricks) tried intermediate profiles, and then the Loft fails all together.
@jeff_strater this should be within the outline sketches, but it's bulging.
Might help....
