Loft preview differs from actual result
Message 1 of 8
I have trouble with the loft command. I am trying to loft two faces consisting of a bunch of (intersecting) regular polygons into each other. When I do this, the preview of the loft command looks as I expect it. If a click OK, however, the resulting body is "twisted" in a strange way. Is this a bug? How can I get a body which matches the preview?
Preview of LoftPreview of LoftActual Result of LoftActual Result of Loft
Replies (7)
Message 2 of 8
-Nick-
In the Edit Feature dialogue box, select Profile 1. In the drop-down that appears, the Profile 1 radio button is selected, change this to Profile 2 and you'll see two more profiles added.  Click OK and you should get this :
I have no idea what is going on here, I was just fooling around waiting for a completely different support problem to get resolved 🙂
Message 3 of 8
masa.minohara
Hi @swt70760,
Thank you for posting! This seems to be a bug to me and I need to escalate it to the development.
In the meantime, could you try grabbing a control points and putting it back to the original position, and hitting OK to see if that fixes the issue? Please see the screencast below for more details about the steps of this workaround.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 4 of 8
Dear @masa.minohara,
Yes dragging the control point somewhere else and back again solves the issue (as does the solution proposed by @-Nick-).
Thank you for your answers.
Message 5 of 8
afoxtierney
Observer
Observer
I tried both the moving the control points around method, and the swap profiles methods with no success. Perhaps I have a different problem, but in any case, I would be appreciative of some assistance. Thank you.
Here is what I expect to result from the loft:What I expect to seeWhat I expect to see
But this is the actual result:The actual resultsThe actual results
Message 6 of 8
davebYYPCU
Your file was misbehaving, I was able to fix it by eliminating ancillary profiles.
Edit your sketches so that the outline is the only solid sketch line, and the smaller outside profile is destroyed, making the unwanted interference, construction lines.
Why is the origin ignored on a cylindrical object?
Might help....
Message 7 of 8
afoxtierney
Observer
Observer
Thank you very much for your help! If it weren't for your help, I might have still had a bare-bulb lamp in my living room!
(I followed your advice and used your fixed file a while back, but just remembered that I had forgotten to thank you)
@davebYYPCU
Message 8 of 8
qbarym
Observer
Observer
I'd like to report, that the problem with loft preview vs acctual results still exists. The suggested workaround of dragging and returning the control point to its original position works. Hope this can be fixed in the future.
All the best.
