Loft is not executed correctly
Hi! I have a problem, I'm designing a glider wing, now I'm working at the dihedral, but I have a problem when I want to connect the 2 ends of the section(one end is tilted at 10 degrees and the other is a scaled from the first one and placed perpendicular on the xy plane) the loft is made, but when I verify and offset a plane at the middle of the body and split it, some features are deformed, I tried lofting in 2 ways: 1.lofting profiles made by sketches, 2. lofting faces of bodies extruded from the sketches, the result is similar.
