local rendering not working
Hi guys I have encounterd an strange issue.
One of my model is not rendering. When I click local render the render gallary is showing nothing. Nothing happens.
I thought there must be some extrude or maybe decals that might causing the issues but there is no way for me to figure out which particular part is causing such issue. Can anyone help me with this? I have been working on this model for many many weeks now and it was render fine before but now no render can be done. Other model works fine. Is it because my model is too complex?
SallyYang
Can you export the model and upload it to side panel, then try the local render again?
Or can you please share the model to sally.yang(a)autodesk.com, so I can have a try. Thanks!
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Hi there thanks for the quick reply! what should I do to share the model to
you?
SallyYang
Please right click your design in data panel and invoke "Share Public Link", then send me the link with downloadable option. Thanks!
Sally
Sally Yang
Autodesk, Inc.
Hi there is there anyway I can send you the link via email?
SallyYang
Please follow my reply above to get the shared link of your model. You can send it to me through private message or email. Thanks!
Sally
Sally Yang
Autodesk, Inc.
SallyYang
Thanks for sharing your design.
I could see the render process running out of memory while rendering.
And after check your model,  I found all the images you used are all 6600*3300 pixels which may consume a lot memory in render. So would you please make the images smaller and try again. Thanks!
Sally
Sally Yang
Autodesk, Inc.
