Thank you that worked
I am having issues trying to attach the guide rails to both ends of the spline when creating a coil, both ends always attach to the same side.
I have tried numerous times and was successful only once. When trying to place the second point at the end of the spline the point that I try to attach to does not seem to exist in space as the cursor does not change when I hover over the end point on the second side.
I am also having a lot of strange things happening such as trying to delete something and it does not happen....shut the program down and restart it fresh, and it deletes right away.
I am starting to wonder if my laptop is up to the task of handling FUSION
Below is what I copied from the diagnostic screen in fusion
[GPU Information]
GPU Device: Intel(R) UHD Graphics
GPU RAM: 128 MB (Integrated card)
GPU Driver API: DirectX 11.0
GPU Driver Version: 27.20.100.9664
GPU Driver Date: 07/05/2021
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Once again thank you in advance for your time
