Link to directory in my windows 10
daanP5JWG
daanP5JWG
Dear Fusion users,
When I want to open/save/export a file to or from my directory Fusion is ignoring my action and goes back to designing screen.
anyone knows a solutions?
Thanks, Daan
Rushikesh.kadam
@daanP5JWG Is it possible to share a video/screencast to understand the case?
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
daanP5JWG
off course
Rushikesh.kadam
@daanP5JWG Thank you for sharing the video. The problem looks similar to the one mentioned here. Can you try the solution mentioned in the post?
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
daanP5JWG
Thank you @Rushikesh.kadam I used the fusion cleaner and reinstalled it. it works!
I am also facing another problem you can may help with:
Take a look at the video, you will understand.
Rushikesh.kadam
@daanP5JWG Good to hear it solved the issue.
For drawing one, I need to reach to the concerned team. Till then, can you create a separate forum post explaining the issue? Maybe someone, a drawing expert, has been in a similar situation and has a solution to it.
Rushikesh Kadam.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
