Line into Curve - Fusion 360
David_Basem
David_Basem
In Fusion 360, if the line is already drawn. How do we turn in to curve from the mid point ? Can we give it a radius defined by the number ?
davebYYPCU
You can add a new curve, connected to a line midpoint.
Set curve radius with dimension.
Then trim the line back to start of curve or convert line to Construction and it will play no further part in the design.
Might help….
jeff_strater
No, you cannot change a sketch object's type.  Lines are lines, arcs are arcs, splines are splines..
Jeff Strater
Engineering Director
David_Basem
How about drawing an arc, three point arc with a mid point that can be slide out to make a curve. I have done that actually making an arc. But how we can give a defined radius ? I can remove the line previously drawn. I am now wondering to give a defined radius to the curve.
g-andresen
Hi,m
dimension the arc
or show in a screencast what you want to achieve in the end
günther
