learning from tutorial
Message 1 of 10
hi guys ive been learning from a tutorial on sheet metal. but when i come to unfold part at the end its not doing it.
as far as i can see ive done all the correct instructions. but im stuck now. can anyone help2020-12-24.png
360 LIVE: Creating HVAC parts in Fusion 360 Sheet Metal
Replies (9)
Message 2 of 10
davebYYPCU
Flat Pattern, or Unfold?  Both should work.
Will need the file for review,
File > Export, and attach it, if you wish.
Message 3 of 10
Ok I will send file many thanks
Message 4 of 10
hi here is the file.
Message 5 of 10
TheCADWhisperer
What is the link to the tutorial?
None of your sketches are fully defined?
Your arcs are not equal length?
This was published before Convert to Sheet Metal existed.
https://www.youtube.com/watch?v=r5GYe1HINB4
Message 6 of 10
https://youtu.be/oGwn6SsyPwA
here is the link , ive just copied exactly what an autodesk instructor has done.
Message 7 of 10
TheCADWhisperer
Examine the Attached file.
Message 8 of 10
Thats intresting beacuse your lofting is quite different. but looks a better way. it would be good to see if i could get more bend lines in to your way?
Message 9 of 10
also many thanks for your time.  you have been a great help.
Message 10 of 10
davebYYPCU
I agree with you the file supplied will not Flat Pattern or Unfold.
Some testing edits could not fix it.
Might not help...
