Latest Update Won't Install - Can't Open DXF File without it
anya.zinn
anya.zinn
At first, the update was stuck at 0%.
I restarted my laptop and I've restarted Fusion 360 several times.
Now the notification is only that the update has failed to load and to post on here.
I tried to manually download the update and install it but it obviously hasn't worked.
I can't open my file with a DXF in it without the update. Please help.
RajkumarIlanchelian
@anya.zinn
1. Currently you do not have any install of Fusion on your machine?
2. If you do have Fusion and it will not update can you go into Help - Support and diagnostic - get diagnostic log files and post the zip file here?
3. If you do not have Fusion installed when you get the failure, does it give you a location to collect logs and post?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
