Latest update causing launch problems on Mac
bentwookie
Message 1 of 36
bentwookie
Fusion 2701.1.18 arm64 [Native]
Active Plan: Subscription
macOS 13.7.8 (22H730) on MacBookPro18,1
After the latest update, I'm finding that loading Fusion on my Mac takes forever and then pops a dialog with these logs:
Error: Could not load the addin in /Users/local/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilder10.dylib
Error: Could not load the addin in /Users/local/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAM10.dylib
Error: Could not load the addin in /Users/local/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.dylib
Error: Could not load the addin in /Users/local/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/CAMXLayer10.dylib
Error: Could not load the addin in /Users/local/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilderUI10.dylib
It eventually launches. I tried using the service tool to repair, but it didn't fix the problem. I guess I'll try reinstalling.
Replies (35)
Message 2 of 36
bentwookie
FWIW, a search for "NaMachineBuilder10" finds this reddit post from yesterday: https://www.reddit.com/r/Fusion360/comments/1rkt78k/excellent_update_guise/
Message 3 of 36
bentwookie
Uninstalling and then reinstalling did not help.
Message 4 of 36
dsouzasujay
Hi @bentwookie
Could you please share the diagnostic log files for further investigation?
How to collect the Diagnostic Log Files for Fusion
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 36
dsouzasujay
Hi @bentwookie ,
When reviewing similar customer cases, we’ve observed that Fusion supports macOS Sonoma 14 and above. Based on this, I’ve suggested that the customer upgrade their macOS version.
Could you please update to the latest macOS version and check if the issue is resolved?
System requirements for Autodesk Fusion
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 6 of 36
bentwookie
Think I'll pitstop on Sonoma while Apple finishes fixing Tahoe 😉
Message 7 of 36
jbullen1
Community Visitor
Community Visitor
Exact same problem here, this is a wider problem now, and would imply that anyone running macOS versions below Sonoma can no longer properly use Fusion. Surely Autodesk can come up with a better answer?
Message 8 of 36
janT7C52
Observer
Observer
I'm on Mac Ventura (13.4.1) and the same problem. Moreover addins like Parametric Text and DirectName stopped working (I get some errors). Contradictory feelings here ... I'm glad I'm not alone in this... and of course I'm not happy that it doesn't work without errors.
Two questions:
1) Can anyone confirm that updating OSX will actually help? I know that my MacBook Pro keeps offering me a system update, but so far I haven't felt like doing it... and since I had no reason to, I didn't do it (updates rarely bring anything positive).
2) Is Fusion broken (cos of those error messages) or it works fine ? For me (haven't time to check it properly) it seems that Fusion features I use works OK as usual ... but I'm not sure
Appreciate reply of more experienced users .. thnx
Message 9 of 36
bentwookie
I'm doing the update to Sonoma now and will report back.
Message 10 of 36
janT7C52
Observer
Observer
Thanks for your willingness to help 👍
I finally decided not to wait and do an update to Sequoia... The OSX update went smoothly and Fusion started up without any errors... Everything seems to be running OK.
Maybe it'd be useful for others ...
Message 11 of 36
bentwookie
Upgrading to Sonoma is indeed enough to fix the problem.
Message 12 of 36
dsouzasujay
Hi @janT7C52 @bentwookie
Thank for the update.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 13 of 36
bonaime
Observer
Observer
I have the same kind of error with Tahoe 26.3.1.
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimVTKExt10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimPostProcessing10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/FEACSObjectsExt/SimFEACSObjects10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimLinearAnalysisController10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimPostProcessingUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimDesignVariations10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/LinearStaticStressExt/SimLinearStaticStress10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimXLayer10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimStructuralAttributesUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/SimDesignVariationsUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/ThermalTransientExt/SimThermalTransient10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/FEACSObjectsExt/SimFEACSObjectsUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/ThermalTransientExt/SimThermalTransientUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/LinearStaticStressExt/SimLinearStaticStressUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/InjectionMoldingExt/InjectionMoldingUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/ThermalSteadyExt/SimThermalSteady10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/ThermalSteadyExt/SimThermalSteadyUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/FluidDynamicsExt/SimFluidDynamics10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/FluidDynamicsExt/SimFluidDynamicsUI10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/ThermalStressExt/SimThermalStress10.dylib
Error: Could not load the addin in /Users/bonaime/Library/Application Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/Autodesk Fusion.app/Contents/Libraries/Applications/Simulation/Extensions/ThermalStressExt/SimThermalStressUI10.dylib
Message 14 of 36
dsouzasujay
Hi @bonaime
Could you please uninstall and reinstall Fusion Application.
While Reinstalling Download a fresh installer and Install.
If the problem persists, please share the diagnostic log file.
If Fusion is not launching
How to manually collect diagnostic log files for Fusion
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 15 of 36
f360CHFH6
I have the same problem on Mac Ventura (13.4.1)
And I can't update to next version of MacOS due to my Mac is 2017 production.
It's sad if Autodesk Fusion doesn't plan to fix the problem for older versions of MacOS, but offered to update the application.
Message 16 of 36
bonaime
Observer
Observer
Uninstalling and re-installing Fusion solve the problem !
Message 17 of 36
ninjadub
Observer
Observer
i have the same did you get fusion to work
Message 18 of 36
WestCoastRCWorks
If the OS version is the root cause, why I do have the same issue on my iMac with Ventura and my M4 mini with 26.3.1.
the previous version worked perfectly fine and intel chips are still supported as well.
Furthermore why can't I downgrade my iMac to get a functioning software package again???
BTW the only package impacted by the error are is the CAM360/manufacturing package and it seems that the permissions for the folder is missing.
That is a fixable problem!!!
Message 19 of 36
f360CHFH6
I can say to confirm, that it's just some unexpected problem with permissions. I tried to reinstall Fusion on Ventura, and it was very strange 4 tries even then on reinstall Fusion. Most of it was exited with permission problem in logs to access to different folders in subfolders of path
/Users/*****/Library/Application\ Support/Autodesk/webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d838e5e/
but at the different subfolders and files.
I tried remove by "rm -rf" the Autodesk folder completely with root perms between attempts, and tried it again and again. I checked with "ps -ef" if some Fusion processes was stuck, as it told in official instructions (Activity Monitor, but doesn't matter) ....
Even restart the Mac several times!
And magic, that from 5th try I reinstall it at least!
But with the same problems as in this topic at the start.
If it's just permission problems, why not fix it for Ventura?  It should be easy.
Message 20 of 36
f360CHFH6
It's work partially, after you confirm list of problems at the start.
But it's starts long time, and exit full screen because of start with errors.
I have errors with CAM360/manufacturing, it's of course don't work in Fusion for my installation.
