Joints with conflicts
alexanderNNTWS
Message 1 of 12
alexanderNNTWS
I have a multi joint construction and if I conneted all the joints the movment is not longer possible. I would insert the model if I knew how to do this... sorry.
Greetings Alex
Replies (11)
Message 2 of 12
g-andresen
Upload this way:
File >export >save as f3d on local drive > attach to post
günther
Message 3 of 12
alexanderNNTWS
Hi Günther,
thanks, here is the file.
Alex
Message 4 of 12
davebYYPCU
Most of the time it is misalignment.
Suppressing the joints in error, makes this area disjointed.
No Timeline - not sure you can fix it.
Might help...
Message 5 of 12
alexanderNNTWS
unfortunatly it didn't help. To supress the joints leads to a wrong movement.
Message 6 of 12
alexanderNNTWS
I think the problem is to connect 4 rotational joints to a kind of parallelogram. It seem that Fusion is not able to solve this constraints.
Message 7 of 12
alexanderNNTWS
is simplified the modell but the problem is still there....
Message 8 of 12
alexanderNNTWS
an most simple model, 4 beams, 4 joints, still not working
Message 9 of 12
alexanderNNTWS
sorry, here is the model
Message 10 of 12
g-andresen
1. Delete joints and origin (not needed)
2. enable history
3. create new joints
(view in My Videos)
günther
Message 11 of 12
g-andresen
same procedure with 4_point_joints
günther
Message 12 of 12
alexanderNNTWS
Super, thanks a lot 🙂
