Joints not moving in eye mechanism design!
kilian.wagnerberger
kilian.wagnerberger
Hi!
I have an eye mechanism design that is based on 2 servos. 1 servo for each axis. The horizontal axis moves without any problems, but the vertical axis seems stuck whenever I want to move it. The joints "jitter". I am fairly new to fusion and especially to joints and assembly. Please any help is greatly appreciated!
jhackney1972
Modified one joint from Revolve to Cylindrical to free up the mechanism.  Your model seems to move OK now.  Model attached.
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask.
John Hackney, Retired
kilian.wagnerberger
Thanks to your solution I figured out that one of my components was clipping into another one by changing it into a cylindrical joint. All I had to do was to rotate the motors vertically to eliminate any horizontal movement. Thanks you!
