Joints help
Joints help
Joints help
So im making a hand right now, and ive made all the joints, but the fingers wont stick together. if the joint i have for the first knuckle moves, everything after the first joint stays in place. How can i get it to move wit the first part of the finger?
jhackney1972
You have to be kidding!  You post a question like this without the model, a screen capture or anything to describe what you are asking.  You need to attach your model.  If you do not know how, open the model in Fusion 360, select the File menu, then Export and save the file to your hard drive.  Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
jhackney1972
Thanks for the model, it sure makes things easier.  I hope I understand your question.  Take a look at the Screencast and see if it helps you do what you desire.  By the way, if you want to move all the fingers together in some fashion, you probably want to do a motion study.  If not, please get back with a very descriptive explanation of what you need.
jhackney1972
A crude Motion Study using Motion Links
That was exactly what I needed, thanks a bunch.
