Joint state using parametric conditional
o1grossman
o1grossman
I'm trying to flip between states of a revolute joint using a conditional in the parameters table.  For some reason the joint doesn't respond when the parameter for the angle is changed using an "IF" statement.  Any thoughts?
davebYYPCU
Works for me, (after the fact) not sure how you were setting it up....
Might help...
jhackney1972
As @davebYYPCU has pointed out, you need to add the Parameter to the controlling Joint.  It would also help your understanding of the IF statement if you add the "Conditional Test" to the statement, in this case "not equal to".  Here is a link to the Fusion Parameters Reference Webpage.
John Hackney, Retired
