Joint bug
Joint bug
daniel_lyall
Mentor Mentor
Joint bug
daniel_lyall
I have come across a bug if I do a major change to a model then in the cam model/file, it breaks the joint origin on a non-changing model that the part is joined to the chuck.
This is how it should look
This is where the joint origin moves to
The joint origin is sitting where the model landed when I inserted it.
To fix it I delete the joint between the joint origin and the model (the joint origin is on the chuck what is also the non-changing model).
Ounces I fix it I can not reproduces the error.
To reproduces it.
Have a model with a joint origin on it then do an insert into current design do a joint between the model and the world origin, then insert into current design another model and joint them together.
Edit the model with the joint origin then run the update in the cam model and it may break the joint.
Just inserting into current design is breaking models with joint origins.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
jeff_strater
Hey, @daniel_lyall , yeah, this sounds bad.  If you have a simple model that can show this, we'd like to have it.  Ideally, a model that is OK, then a set of steps to reproduce the problem (e.g. "edit the design, add a fillet, save, go back to the top and get latest") would be the best.  But, even a broken design might be helpful.  I'll try to reproduce it from your steps, as well.  Thanks!
Jeff Strater
Engineering Director
daniel_lyall
I can not reproduce it this morning I will post back when it happens again.
Daniel Lyall
The Big Boss
Mach3 User
