Joins with revolution and contacts set does not do 360° regularly, but start and stop. Is this a bug ?
Le_Bear
Le_Bear
As images are better than a long text, I'll put a video. If I try to manually turn (with the mouse) my driving wheel, I can't do 360°, but it does 360 no problem if I animate just this join.
(view in My Videos)
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
akash.nawghare
I am unable to reproduce this in my machine.
Could you  please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
Le_Bear
Thank you for your answer. I thought about attaching my model after posting, sorry. Here it is
Bernard Grosperrin
akash.nawghare
Please find the attached video & Fixed f3d file. I have updated the Snap selection now this Joint is working as expected.
"If you find my answer solved your question, please select the Accept Solution icon"
(view in My Videos)
Le_Bear
Thank you. I have to look in depth to understand what you did, seems a bit strange to me for now... Very much apreciated.
Bernard Grosperrin
akash.nawghare
Thanks a lot, feel free to ask if you any concerns/queries, Thanks a lot.
