Joining sketch curves to create one continuous curve
nthomas0051
nthomas0051
 Is there a way to join the sketch curves so I have 1 tangent continuous line? Currently I have 18 sketch curves so I cannot sweep the pattern I want to sweep.  I've tried using the extend tool and the blend curve tool.  I've even tried projecting to the original outline into a new sketch.
jhackney1972
You could try to select the Coincident Sketch constrain and then Window select all the sketch.  Please attach your model for better help.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
jeff_strater
"Currently I have 18 sketch curves so I cannot sweep the pattern I want to sweep"
nothing that I see should prevent a sweep.  Is that the path or the profile?  The short answer is:  no, there is no facility to combine curves in Fusion.  It is generally not needed because operations accept a chain of connected curves for profiles, paths, rails, etc.
Jeff Strater
Engineering Director
