Job Log stuck
Job Log stuck
vincentsubsurface
Job Log stuck
vincentsubsurface
Good Morning.
I have had a file stuck in the "Job Log" for several days now.
When I close f360 I get " you have 9 jobs in queue". doesn't matter how long I leave it, not progress.
I have tried:
1. closing and reopening F360
2 clearing cash
3 repair utility
4 uninstall, reinstall
5 run as admin
6 delete the file in question.
All to no avail.
Please help.
Cheers
Andrew
RajkumarIlanchelian
@vincentsubsurface Can you please try the below:
1. Close Fusion 360
2. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\P.login\DELETE jobs.json
3. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\W.login\DELETE folder Q
4. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\W.login\DELETE UploadQueuedFileList.xml
5. Now start Fusion 360
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
vincentsubsurface
Thank you @RajkumarIlanchelian
Seems to have worked.
Still, have a ghost of a file in the job queue. but on exiting f360 the job queue is clear.
Cheers
