Jagged edges using Sweep tool to create coil
bigonvalue
Message 1 of 9
bigonvalue
Hi All,
(1) Getting jagged edges on my coil, rather than a nice smooth surface:
Does anyone know how to remove these edges?  I tried saving as an OBJ and it included the edges.
(2) I tried saving my coil as a STEP file — it ended up 6.8GB in size?  Ideas?
Replies (8)
Message 2 of 9
wmhazzard
There are empty sketches and missing geometry for the construction plane and sweep and multiple bodies. I would start over and keep everything in one component for the body. Maybe that will fix the coil.
Here is how I would do it.
Message 3 of 9
bigonvalue
Thank you.  After the sweep, how do you restrict the pipe from only following the outer edge of the coil?
Whenever I apply the "Pipe" tool, it follows every path, including the original sketch.
Message 4 of 9
wmhazzard
Deselect chain selection in the pipe command and it should work.
Message 5 of 9
bigonvalue
Once again, thanks for your help!
Done some testing....I found Fusion does not handle larger twist angles.
When I increased sweep twist the file you sent to 15000, it looses its smooth curves and becomes angulated
Seems to produce smooth curves up to about 9000?
Message 6 of 9
wmhazzard
It does look like it can't handle the high twist.
Message 7 of 9
bigonvalue
Even more issues when you try and align one end of the coil cord. Fusion simply crashes.
Message 8 of 9
wmhazzard
What are you trying to do with the coil, is it aesthetic or functional?
Message 9 of 9
bigonvalue
Aesthetic for prototype imagery at the moment.
