You could try and use another method to access the internet to determine the problem. You could try using a network cable to your Router directly or maybe try using the Hotspot on a mobile phone. If one of these works then suspect the Wi-Fi connection you are using. If you are using Windows, then maybe you Firewall settings are too tight. Turn it completely off temporarily and see if that helps, if so, adjust your Firewall settings according to Fusion needs.
John Hackney, Retired
