Issue with SVG extruded from Revolved sketch
Something strange happens, when I try to extrude SVG from Revolved object.
Where goes line, SVG cuts, and not appear at all...
Screenshot 2019-10-03 at 09.28.38.pngScreenshot 2019-10-03 at 09.31.22.pngScreenshot 2019-10-03 at 09.30.09.pngScreenshot 2019-10-03 at 09.29.17.pngScreenshot 2019-10-03 at 09.28.44.png
g-andresen
The screenshots do not show the position of the sketch.
If a part of it  is outside the body, there is no cut-extrusion.
Please share* the file.
günther
*File > export > save as f3d locally  > attach it to the next post.
jeff_strater
I can reproduce this.  Any profile that extends across the seam will not extrude if you pick "from object" as the source:
We will investigate this.
[edit]  Fusion bug FUS-54955 created for this issue.
Jeff Strater
Engineering Director
Thank you! 😉
patrick.risser.510
Screenshot 2022-01-20 104925.jpgScreenshot 2022-01-20 105035.jpghi theses posts are 3 year old but the issue is still not fixed on the latest version 2.0.12157
any chance to get it solved ?
thanks
Patrick RISSER
PARIGEN smart & Lean Consulting
LinkedIn
