issue with stl when imported as mesh
rdfry
rdfry
i have an stl of a case for an electronic device. it is a top and bottom combined as one body. i divide it into 2 separate bodys. it shows that it is hollow like i need it. however i can only work with the outside of each body. the internal sides act as if they are invisible. if i export back out as an stl and slice them they print completely solid. M5-Stack-Core-Eink case split.pngM5-Stack-Core-Eink case.png
TheCADWhisperer
@rdfry wrote:
... it shows that it is hollow like i need it.
I see infinitely thin walls.
In the real world don't walls have thickness?
rdfry
here is the file. thank you for helping
