Issue with extrude tool picking random features
atl76
Message 1 of 8
atl76
(view in My Videos)
This has been driving me crazy and it is happening on a few of my files. You cant see the extrude tool window because of the recording software I am using but it is there. Also the sketches all appear to be closed so I don't know what I am doing wrong.
Replies (7)
Message 2 of 8
jhackney1972
Please attach your model so the Forum users can take a look.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
Message 3 of 8
atl76
Here it is
Message 4 of 8
jhackney1972
There does seem to be an issue with the extrusion of two of the bosses but you method should not be use anyway.  Your sketch is way to complex as you should only sketch one boss, extrude it and then pattern that one boss around the rim.  This keeps your sketch simply and the application functions better.  Video attached.
(view in My Videos)
Message 5 of 8
atl76
I couldn't use circular pattern because it wouldn't work for ovals (when parameter DVert and DHorz are not equal, which is most of the situations this part is used in) but I understand the sketch is very complicated, I think a radial pattern geometry tool would be helpful or some other method. I ended up fixing the issue by just starting a new file so I'm still not sure what the issue was.
Message 6 of 8
g-andresen
Is that the intention?
günther
Message 7 of 8
TheCADWhisperer
Then use Pattern on Path. Or Mirror 1/4
You are using computationally expensive sketching techniques.  You will continue to have difficulties.
This can be significantly simplified with computationally efficient techniques.
I am confident that the issues can be addressed and resolved to result in robust and predictable behavior.
Message 8 of 8
obulesub
Hi @atl76,
Good evening!  did you get a chance to look into the previous message from TheCADWhisperer. Please check and let us know your response.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
(Obulesu Bodika)
