Issue with Countersink tapped holes
brent.bulgarelli
brent.bulgarelli
When using the hole tool to make a countersunk tapped hole, the threads have a tendency to begin below the countersink rather than going through them. This results in an issue where there is interference between the screw and the tapped hole; see attached.
HughesTooling
Yes this is a known limitation reported years ago! The workaround is, first create the threaded hole with cosmetic threads, no chamfer then add the chamfer as a second feature then edit the hole and change to modeled threads.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Just to be clear. Create the thread as one feature and the chamfer as a second. PS, please don't attach pictures, just paste them into your message.
Mark Hughes
brent.bulgarelli
Thanks Mark!
Worked like a charm!
