Issue when using the fillet tool
kelvinclark
Observer Observer
kelvinclark
Observer
Observer
Hi Guys,
Newby here playing about with the application and scratching my head when trying to fillet edges.
As you can see from the image below, my edge won't fillet to 0.10mm and I get the red line and warning. It does let me fillet to 0.05mm however??
The oval shape extrude on the right lets me fillet to 0.10mm just fine.
I'm perplexed.
TheCADWhisperer
Are you using Tangent constraints on the sketch that creates the geometry?
kelvinclark
Observer
Observer
Hello and thanks for your reply.
The model originates from a 2D file which was extruded,
I'm trying to get rid of all 90 degree corners, so fillets everywhere, which is proving to be difficult.
File attached.
Thanks.
TheCADWhisperer
The geometry appears to be poor quality import... ...I cannot add Tangent between all curves.
I do not see where you mention Import or the source of the original geometry.
I would use only as reference in recreating native (tangent) arcs in Fusion.
jhackney1972
The best Fillet radius I can get on this very tiny model is 0.12mm.  Model is attached.
John Hackney, Retired
