Issue importing step file
Hello, I am trying to open a step file that contains a polyline in Fusion 360, but I can not visualize it.
Any thoughts would be appreciated.
pawel.potyrala
Hi @Anonymous,
thanks for posting! Would you be able to attach the original STP file you are uploading to Fusion 360 for me to test? Could you explain in a few words how it was created?
Thanks!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
Thank you for you reply @pawel.potyrala !
Could I send you to your e-mail?
Thanks.
HughesTooling
Fusion doesn't import anything apart from surfaces and solids from stp files. There was a request for import of curve data on the ideastation that got marked archived with a note that Fusion should import curves in stp\igs files but it doesn't work with any tests I and others have done.
Mark
Mark Hughes
Owner, Hughes Tooling
