Is there a way to change the 'Animate Joint Relationships' speed?
crueby1
Message 1 of 8
crueby1
I have an assembly with a series of joints, all working fine. When I select 'Animate Joint Relationships' everything moves round, but I'd like to view it at a slower speed to get a better look at things. Is there a way to do this, other than create a motion study or driving the first joint manually? This would also be very helpful when I am capturing a video of the joints in motion using a screengrab tool.
Replies (7)
Message 2 of 8
mayank.malukani
Hi @crueby1 ,  Thank you for reaching out. Maybe the 'Motion Study' command is more in line with what you want to do. Can you give it a try?
Message 3 of 8
crueby1
Hi mayank.malukani
The motion study does allow slowing it down some, but not all that much. Would be great if that had more range on the speed slider to the 'slow' end, the motion still goes through a full cycle there in just a couple seconds.
Message 4 of 8
jhackney1972
Open up your text command window and type the command Fusion.Jointanimationtime a space and the number of seconds of duration you desire.  For example Fusion.Jointanimationtime 10
Make sure you are entering your command in Text, selection in on far right hand side of text dialog window.
Edit: Here is a Fusion.jointanimationtime of 10.
John Hackney, Retired
Message 5 of 8
crueby1
Hi John,
That is perfect! Just what I was looking for - thanks SO much!!
Chris
Message 6 of 8
crueby1
jhackney1972 - another question if I may, is there a way to assign that command to a shortcut, hotkey, or other menu item? I can see using it a LOT, and it resets next time I start Fusion.
Thanks!
Message 7 of 8
jhackney1972
I am sure it can be done using Fusion API but I am sorry to say I am on a user or programmer using the Fusion API.
Message 8 of 8
crueby1
Thanks anyway - appreciate the time!
