I've created a sketch that I'm using to do a sweep cut along a path. Here's a picture to show what I'm doing (the sketch is the blue profile and it's cutting along a curved path).
I have multiple bodies throughout my project that I'd like to do this sweep cut on, and currently what I'm doing is creating a new sketch on a plane perpendicular to a face of each body and then copying the original sketch from place to place.
The problem with this approach is that if I need to modify the original sketch, I would then need to manually modify every other copy in exactly the same way to have a uniform sweep cut across all bodies in my project.
What I'd like to know is if I can use just the original sketch (in a parametric manner) in different places so if I need to change the cut outline I only have to do it in one sketch and all the other places it is used will update automatically.
Is this possible?
Thanks!
Brian
