Is it possible to bind "look at" to the spacebar key?
Im new to Fusion 360, and would like to bind the "look at" command to the spacebar(or any key). Any ideas?
ryan.bales
Autodesk Support
Autodesk Support
Yep you certainly can. I do not recall if spacebar is keyed to anything else but to change it, open the text commands, make sure you are set to txt and type
hotkey.dialog LookAtCommand
It'll open the shortcut dialog for the 'hidden' command and allow you to assign or key it in. Spacebar works here as i've just tested it. The syntax is incredibly important and must be what i wrote above.
You'll know its correct as it will say 'look at' in the dialog and 'invalid command if wrong'
Ryan Bales
Fusion 360 Product Support
thanks!!!
