Installing Free Fusion Version
leslieFRT9A
leslieFRT9A
I have Fusion installed and have been using it for some years.  I am retiring now and on my request have had the Free version activated and in my Products & Services section of my account.  I have downloaded the EXE file and attempted installing the new download.  I already have and still licensed the Fusion installation I have been using for years.  When I attempt to install the new version I am advised the latest Fusion version is already installed and asks if I wish to open it.  On accepting that I am presented with a window "Problem installing Fusion" [winerror740].
I was advised by a Fusion assistant that I can have both the Paid licensed version and the Free version on my PC at the same time but I am wondering if that is the case and do I need to uninstall the existing version. My fear is that I will uninstall the existing version and then still not be able to install the free version and will be without access to my Fusion files and the application.
I have attached the log files from the failed installation.
I hope someone can help with this as my existing subscription will end in a few weeks.
Regards
dsouzasujay
Hi @leslieFRT9A ,
This is most likely a permission related issue. Could you please review the article below and check if it helps resolve the problem?
"WinError 740"​ and Fusion 360 fails to install
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
leslieFRT9A
Thank you for your response. I subsequently chatted with Jean-Bernard at Autodesk and he has resolved my problem we think.
Regards
dsouzasujay
Good to know @jean-bernard_odon solved the problem.
Thanks for the update.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
