Installation error due to server problem
koushik.ch2019
Observer Observer
koushik.ch2019
Observer
Observer
RajkumarIlanchelian
@koushik.ch2019 Searching for "Fusion 360 errno 2" in the forums shows a lot of posts on how this could be solved. One such post is this - https://forums.autodesk.com/t5/installation-licensing/install-fusion-360-failed-tips-quot-lt-urlopen...
Can you please try the solution to see if this worked for you?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
