Insert photo-insert canvas menu will not open file WIN10/AMD RYZEN/GTX1060x
subversivespeed
subversivespeed
Win10/AMD Ryzen/GTX1060x will not allow you to "select image". The dialog file selection box does not open. It works fine in other machine which is win7/Intel i7/GTX560.
Tried changing the direct X type and used both DX9 and DX11 and does not change behavior.
Likely an easy fix. Get on in folks. 🙂  Now if MS would just quit playing with Win10.. This started happening after recent forced update. (updates on all my machines are turned OFF but yet here we are)
masa.minohara
Hi @subversivespeed,
Thank you for posting! Could you try the Reset to Default Layout option in the File menu to see if that helps?
If that doesn't help, could you try cleanly uninstalling Fusion and then re-installing it to if that fixes the issue?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
