aluminium composite claaddingPleas
Hello everyone,
I am currently working on a project that involves using aluminum composite panels (ACP) with aluminum skin on both sides and a mineral core in the center. The ACP sheet comes in 4mm and 6mm thicknesses, with both having the same skin thickness of 0.5mm.
I am planning to fold the panels by cutting grooves using a grooving tool with a 4mm tip width and 3.2mm depth for the 4mm ACP sheet, and a 5.2mm depth for the 6mm ACP sheet.
However, I am unsure of the metal rules that should be applied for this type of material and groove dimensions. Can anyone provide guidance on what metal rules should be used for ACP sheets with these specifications?
Thank you in advance for your help and suggestions.
e
