Inported CAD i posted wrong plan in Fusion 360
conny_olsson
conny_olsson
Hello
When I import CAD that is drawn in top planes, it ends up on the wrong plane in Fusion 360. CAD comes standing in Fusion.
Is it a setting or how can I make the imported CAD end up on the same plane as it is in the original CAD.
Yours sincerely,
Conny
TheCADWhisperer
XYZ is XYZ in both programs.
The orientation (relative to XYZ ) appears to be identical.
Go to the View Cube in upper right corner of Fusion.
Set to XYZ to how you want to view.
Right click on view cube and set as Home.
Set View Cube to what you want designated as “Top”.
Right click on View Cube and select Set as Top.
If you still have trouble - can you Attach your *.sldprt file here?
