Incorrect dimension calculation on centerline in broken view
hettematechniek
hettematechniek
After the latest update (Fusion 2604.1.25 x86_64), dimensions on centerlines are being calculated incorrectly in broken views. The attachment shows a dimension on the centerline and on the contour, both with different values.
dsouzasujay
Hi @hettematechniek
Can you please attach designs that you've completed in Fusion?
Please export your design as a *.f3d/*.f3z file to your local drive and then attach it to your reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
