Inconsistent behaviour and errors of Draft modification of extruded SVG drawing
fallenartist
fallenartist
G'day,
I'm trying to create a 3D stamp from a SVG drawing. It imports well, however problems begin when extruding shapes with side walls set at an angle (10 deg slope in my case).
I tried both Extrude and Draft and both produce errors on some edges. Straight edges are fine but some curved ones prove problematic. I can't understand the problem because seemingly more complex curves produce expected slope but some don't. In one case mirrored curves produced opposite results – one worked and one didn't.
Is this software limitation or a bug? How can I overcome this? I'm attaching my files.
Thanks.
rohit.bapat
Hello @fallenartist
Thank you for posting the query. We confirm that this is a valid issue and we have logged a ticket to track it.
Rohit Bapat
Product Owner
fallenartist
Hi @rohit.bapat
I haven't got much luck with the latest update of F360. Is this still ongoing and can the ticked be tracked somewhere?
Thanks & regards,
Alex
wmhazzard
I have found that using chamfer with distance and angle is more reliable than using draft or extrude with angle for more complicated geometry.
