In Form Context Environment, adjusting the T-Spline Parameters
mattb1969
mattb1969
I’m currently doing some design work using the Form contextual environment, especially  the Cylinder command
When I create the cylinder, I complete a number of settings, including the width, height etc, see below:
My question is, with virtually every other element of Fusion, I can go back and change the settings afterwards, but with this feature, I can’t find any way to do this.
I am using the free Personal licence.
davebYYPCU
Once you fill in that dialogue box, and Press Ok, the dialogue box is gone forever, for that body.
Form is the same as sketches you can edit all you like but they have no parametric history.
Might help….
TrippyLighting
T-splines are not parametric in the sense that you can go back and edit parameters.
When you continue to work with T-T-Splines, it becomes clear why that is the case.
