impossible drafting with SVG file
mirandablake90
Observer Observer
mirandablake90
Observer
Observer
I am creating a cutter.  I need the cutter to be sharp.  Usually I draw my own, but I wanted to try to import an SVG, use its outline and create the same sharp cutter.  When I try to do this, it never drafts out. Not even  a little.  What am I doing wrong? It seems as if there are too many lines in the svg.  Is there a way to reduce those? Am I just trying to cheat too much?
g-andresen
please share a sample SVG for reply
günther
mirandablake90
Observer
Observer
I'm offsetting it at .33, extruding to 12mm, trying to draft to 6 or at least 8
