If statement issues
If statement issues
ubi.james13
If statement issues
ubi.james13
Hi, have a family off parts and dependent on length they require different number of holes, below screen grab is from
Fusion 360 Help | Parameters reference | Autodesk
I've basically cut and pasted in to my part then change parameter name & value to suit my needs but for some reason this will not work ?
g-andresen
check your equation
qty holes = if(total_lenght < 199 mm; 2; if(total_lenght < 1200 mm; 3; 4))
günther
ubi.james13
@g-andresen thank for your help, expression is now working ! Does this mean the example on web page is incorrect ?
g-andresen
Yes!
Take a  look here
günther
HughesTooling
@Phil.E Can you take a look at the parameters help section for the if statement. The first example is correct but the bit highlighted in green has an "if" missing.
Mark Hughes
Owner, Hughes Tooling
