I want a curved cylinder that leads from Sphere to Sphere.
I don't know if you will understand from the attached picture.
If you look at what I've done now, it doesn't fit perfectly in the middle of the sphere and the length of the basic coil is too long.
I want to start from the middle of the sphere and shorten the length of the coil.
TheCADWhisperer
File >Export and then Attach your *.f3d file here.
jhackney1972
I hope I understand your desired model, if so, download it and take the timeline apart to see how I did it.  If correct, you can thank @TrippyLighting for the spiral tube technique.  He showed me the technique in another post.
John Hackney, Retired
Thank you, I've studied a lot!!
but, Pipes are made on every sketch(?).
g-andresen
uncheck „ chain selection“
günther
