I use fusion 360 on a mac and I am a beginner
FacebookGroupMember
Message 1 of 11
FacebookGroupMember
I use fusion 360 on a mac and I am a beginner. When I start a sketch and choose the plane to sketch on the plane dosn't turn to the scetch plane. I have to choose the right view in the top right before i can start drawing. Is there something i can correct this
Replies (10)
Message 2 of 11
FacebookGroupMember
That's normal you can click look at in the sketch plate or set in your preferences
Message 3 of 11
FacebookGroupMember
Daniel Lyall thx. That works fine for me
Message 4 of 11
FacebookGroupMember
I do this as well but it doesn’t bother me
Message 5 of 11
g-andresen
check the settings in your sketch palette
günther
Message 6 of 11
FacebookGroupMember
What would that do?
Message 7 of 11
g-andresen
This means that when you start the sketch, it automatically switches to the active sketch layer.
However, this setting must be activated in the preferences, which I generally assume.
günther
Message 8 of 11
FacebookGroupMember
Autodesk Community I am fairly new to fusion but learning it and slowly designing some good stuff BUT where are the preferences.... despite extensive searching I just can’t find it. 😳 . A bit weird really. 😀
Message 9 of 11
seth.madore
Seth Madore
Message 10 of 11
FacebookGroupMember
Autodesk Community thx this is the trick I needed
Message 11 of 11
g-andresen
I'm glad it worked.
Please mark contributions that made a solution by checking them as "Accepted Solution".
This will make it easier for future readers.
günther
