I need to move this hole but cannot, help please
tolgak7PA6Y
tolgak7PA6Y
I got this guitar body:
original position.jpgWhich I need to turn into this:
When I try to move the hole it says "Warning: Additional faces have been moved. Some faces could not be moved without also moving adjacent faces".
Could someone please help me with this? The space between the neck pocket and pickup should be 8 mm as seen above.
I am attaching the f3d file.
Thanks in advance.
jhackney1972
Ignore the warning.  Fusion is just telling you that other faces have to be moved to do the move you desire which is true.  The surrounding faces have to adjust to the new location also.
John Hackney, Retired
tolgak7PA6Y
Ye but the result is a mess. It becomes like this:
jhackney1972
Sorry, I had the wrong pocket.  I took some shortcuts so be careful with the new sketch.  Model is attached.
tolgak7PA6Y
It works perfectly now jhackney1972, cannot thank you enough. I am extremely grateful.
Cheers!
