I need help
I need help
FacebookGroupMember
Message 1 of 18
I need help
FacebookGroupMember
I need help. I'm trying to take the selected face and move it laterally by 20 mm to create a slant. I have tried EVERYTHING I can think of and I get nowhere. It's so frustrating because I am certain that it's something simple.
What am I doing wrong?
Replies (17)
Message 2 of 18
FacebookGroupMember
Make sure the face is highlighted and put the move icon on one end, the corner or the middle should do it, then use the angle handle to change its angle.
Message 3 of 18
FacebookGroupMember
Daniel Lyall, how? This is literally the one thing not covered in my instructions.
Message 4 of 18
FacebookGroupMember
Have a look at this https://autode.sk/3sZ6H8a
Message 5 of 18
FacebookGroupMember
Daniel Lyall, thank you but I wasn't talking about that. I want to take that face and move laterally. So that face will make all the slots lateral at an angle. As is, they remain vertical. (What I am suggesting is a basic function of virtually every 3d editing software, this shouldn't be a hard ask.)Do I have to I have to extrude at an angle? How would you do that?
Message 6 of 18
FacebookGroupMember
Yes, that would be a draft it's under the modified menu. Extrude the holes straight down - select the faces you want to be moved as the faces then select the top for the pull direction then do the same thing again to the opposite side.
Message 7 of 18
FacebookGroupMember
Daniel Lyall, thank you.
Message 8 of 18
FacebookGroupMember
Thank you, but that isn't what I am looking for either, it's just a different way of doing the the exact thing that I don't want to do. It's hinging the face upward and downward. Not moving the face laterally, in any sense of the Word. It does this...
I appreciate your help, I really do. But I think I am miss communicating.
Message 9 of 18
FacebookGroupMember
Joshua Eichler Can you do a sketch profile of the shape you want?
Message 10 of 18
FacebookGroupMember
Daniel Lyall, on the outside. But not the interior.
Message 11 of 18
FacebookGroupMember
like a split view
Message 12 of 18
FacebookGroupMember
How do I do that?
And thank you VERY much for being so patient with me.
Message 13 of 18
FacebookGroupMember
Try this you have an addon for fusion called screencast get your self this https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Message 14 of 18
FacebookGroupMember
Then do a section analysis of the part sect a long faces and push it in so it goes into the model, then use this visual to explain what you want.
Message 15 of 18
FacebookGroupMember
This is what I was meaning with the draft tool https://autode.sk/39u4z0F
Message 16 of 18
FacebookGroupMember
Did you use one sketch to make this?
Message 17 of 18
FacebookGroupMember
Erik LaFleur, I don't know how to do more than one.
Message 18 of 18
FacebookGroupMember
You could create a plane on an angle and then split the body and cut the part You don't need away all together If I'm understanding your question correctly
