I'm only allowed to select one face at the time to draft
a_sorensen
a_sorensen
Hi everybody. I'm working on a part and wanted to use the draft command. But after selecting the pull direction, I can only select one face at the time to draft. All the faces can be drafted without any problem, but I have to create a new draft command for each face and it creates unneccesary many actions in my timeline.
g-andresen
Please share the file and tell which faces you are talking about.
File > export > save as f3d on local drive  > attach it to the post.
günther
jhackney1972
How does my process differ from yours.  I am creating a Draft of three sides all at once.
John Hackney, Retired
HughesTooling
My guess is you have a size set for the draft so it's applied as soon as you select a face? Either set the draft to zero while selecting or hold the Ctrl key down to add faces to your selection.
Mark
Mark Hughes
Owner, Hughes Tooling
a_sorensen
Holding ctrl when selecting did not work when I had the problem. And I can't remember if I had a size set for the draft, but I tried many times (going out and back into the function). But after a while it suddenly worked, so that may have been the problem and solved accidentally. Thanks.
