I cannot open my model on my 2nd computer
beatified
beatified
In looking at the version number of the two installs of Fusion 360 the one I am unable to open the model in is clearly an older version. I have even tried exporting the f3d file and opening that instead of doing it over the cloud.
I have tried updating but every time I do it says I have the latest version.
Versions
2.0.13162 wont open file.
2.0.14337 opens file fine.
Operating systems are different older version is on windows 10 and newer is on windows 11 maybe the update isn't available for windows 10????
I get "unable to open" it may not have synced correctly.
sutherland-
Dear @beatified
Are you using the same account when logging-in on both PC's?
Best,
Kritzz
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Steven_Gao
If the design was saved on the newer Fusion 360 version. You need to update the older version on windows 10 to the latest version. If the auto-update of Fusion 360 is not working, you can uninstall/reinstall it manually.
Steven
RajkumarIlanchelian
@beatified Version 13162 is from our May 2022 update. The other version you have is our latest update. Files saved in the latest will not be backwards compatible with older versions.
AS mentioned, I would go into the machine with older version, Go to add/remove programs, Select Autodesk Fusion 360, select Edit and this should launch the Fusion service utility. Select "Fusion repair" and this should get you to the latest version.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
beatified
Thank you Add Remove Programs and Repair updated it even when trying to manually update to the latest version.
Thanks, All is good now.
