I cannot move files from personal account to commercial account via Fusion Team?
I have a previous personal account and a new commercial account.
I would like to move my files from the personal account to the commercial account via Fusion Team.
I have made a Team and it shows just fine in My Hub.
The problem occurs when I am to move the files; they won't move...
I have tried drag and drop and in Bulk mode - but nothing happens?
What am I to do here?
Regards
Michael
jhackney1972
First the big "if".  If you have Fusion 360 installed on the same computer and you at one time log into Fusion 360 with your personal license Autodesk ID and then at another time log into Fusion 360 with your subscription Autodesk Id then you have a couple of options.  Log into using your personal license Autodesk ID and open the files you want to transfer and on each go to the File menu and select Export and save them individually to your hard drive.  You can then log in with your subscription ID and open them from the local drive and save them to your cloud Fusion Team.  The other option is a little trickery.  While in your personal log in you can go to the data panel and choose files you desire.  You can right click on folders or files and choose "Add to Offline Cache".  This saves them to your hard drive under your the personal license ID.  The trickery part is locating them and then logging into Fusion 360 with your subscription account, opening them and saving to your Fusion Team.  I would stick to the first option, it is way more controllable.
If the big if is not true, you can still use the first option but you will have to copy the files from one computer to another.
John Hackney, Retired
