I can't work out how to join these two bodies
collinsbenji13
collinsbenji13
Community Visitor
Community Visitor
Hello. I'm trying to combine two solid bodies but I keep getting the error:
"Error: There was a problem combining geometry together.
If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
Failed to Boolean bodies together"
There is definitely overlap between the two, I can't see any weird edges or faces. They are fairly simple shapes. I have attached the f3d files. What steps should I try next? Please note that this is a part for a toy.
Thank you in advance.
TheCADWhisperer
@collinsbenji13
Why is your first sketch (and all other sketches) not fully defined?
Why use stl faceted geometry rather than clean Revolve?
Step1. I would move the Canvas such that the Origin is in a logical location (and is the Canvas the right size?).
As I start to remodel this from scratch - as I add missing dimensions they do not make logical sense?
If I do a Compute All (CTRL b on Windows or CMD b on Mac) I get a whole list of unresolved issues?
I am left with a conundrum of how to proceed without calipers and the actual part?
I can try to reverse-engineer the imported meshes and try to decipher true Design Intent...
I can recognize some Face Groups...
And generate a Prismatic Model...
Bit-by-bit I build the geometry...
