I can't make a pipe from my spline
jdoger95
jdoger95
I can't make a cylinder pipe from the spline I made, I just keep getting errors. any ideas?
g-andresen
delete point!
günther
MoshiurRashid
Hi
Thanks for posting. Here is a screencast that I made for you which completely describes what's preventing your spline to apply pipe command.
Link: https://autode.sk/2Rt8GAE
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
jdoger95
thank you for your video it is very detailed and helps a lot.  I have a new issue now when I try move my pipe it changes the shape of the pipe.  here is the video https://autode.sk/2XDTpB1
g-andresen
select : move object > bodies (not faces!)
günther
MoshiurRashid
@jdoger95  It is happening because, you have to understand the move command.
There are 2 things you're doing wrong.
1. In the move command panel, you selected "Face" instead of "Bodies". Face moving is a direct edit command which allows to change dimension. Body move is just used to move body.
2. Clicking the move triad "scale" plane sometimes. You should only click and drag the "Arrow" of move triad to move. Not the planes or the wheels. See the picture below.
Please Accept those solution if they were helpful. So that people who face similar problem can find it quickly.
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
jdoger95
thank you for helping me. I have never see "move face" before, it is all fixed now. thank you all for your amazing help
